  • Replies 41
Speak to your dealer, there is an upgrade which can be carried out under warranty. I had mine done and it transformed the saw.
Do you know what they did to the saw kev?
On another note 2 years isn't bad, I'd say that's about right for a topper.
I wouldn't be happy with only 2 years from a new topper.
I'm still regularly using a 200T that I bought in 2004.
what is the difference between the old and new 201t?
Ignition advance and better porting. The new 201tm will be out soon anyway. There's also a magnum muffler...
Mine got carb, coil, pot, piston, flywheel I think but I don't think all that was part of the upgrade as such, some people say the carb is a different issue. If you have a switched on dealer talk to them. I spoke to Stihl at the AA show who said to send it back and get the dealer to call Stihl technical so I did and a week later the saw came back to me fixed. I have got one of the first 201T's and had a new carb on it 2 years ago which didn't make much difference. This new rebuild/refresh makes a massive difference.
Good for you. I maintain that for a small saw like that used every day, 2 years is a decent life expectancy.
I have refurbed many MS200Ts 10-12 years old, there are typical components that do fail but the saws are still able to perform and are far better than the earlier version of the MS201 - cant comment on the later ones!
You asked what a service includes, my services get the saw back to full working serviceable order with new parts to avoid failure in the near - mid future - replacing clutch springs is a regular occurence as is chain catchers - it stops the saw failing in a months time for £5 worth of spares!
My local dealer does not do repairs in their workshop! they get sent to manchester then 3 weeks later they come back! as i found out :thumbdown:
Sounds expensive all that, after 2 years the saw is probably out of warranty? right?
