A few questions for the gang... what is biggest bar I can fit on to my 560? Secondly, in percentage terms how much more power can I get out of the 560 if I get it ported, also will porting increase the revs too or just increase power. Thanks.
  • Replies 160
I think the blue coil will limit the revs in fresh air but mine spins up quicke and is stronger in the cut . Louder too :001_smile:
Been reading about people suggesting fitting a 562 air filter to a 560 to get gains . Now as I see it you will need the high top filter cover (easy enough to come by ) and the 562 filter itself,that has deeper gills ( so overall height is greater ) this leads me to think you would need a tall inlet throat to mount it on ( like on the walbro verses Tillotsen carb on a 394/395 ) Any one over the pond confirm this ? Troll , any one ?
Looking up the IPLs should tell you what you need (they are on several Husky websites, if they aren't on the UK one, look at the Swedish or US one) - but I seriously doubt you will gain anything but bulk and weight by doing it - unless you are in very "dusty" conditions.
If you want as much air as possible in, use a nylon mesh filter.
Not set up means it is not in the UK inventry, the wrap handle and filter is set up, however the top cover is not
Just bought the top cover a few mins ago so thats covered .
As far as I'm aware, the wrap is unavailable in Europe, unless the rant to husky Sweden actually worked?
Just checked, the wrap handle is set up, but the top cover in the latest ipl is not so there is no way it came from Distri parts.
My top cover is coming from the U.S.A. . OEM part not pattern . About £12 .
Edited by Stubby
