Just been asked by a customer for availability on the filter and cover.
The cover has a different part number from what husky UK list on their IPL, they list 587 24 87-01 whereas 522 95 96-01 is what is showing as the 562xp cover which husky UK do have in stock!
If anyone could do ma a favour and confirm the above is 100% correct in regards to 522 95 96-01 it would be very much appreciated, as I have only gone off internet info rather than seeing the thing first hand.
They dont have any of the yellow filters but do have the 80um black one availabe :001_rolleyes:
  • Replies 160
There is two part no.s for the 562XP top cover, 522959601 and in the 2014 list the no. is 587248701 both cover are the same, the 2014 cover just has a new decal on it giving starting instructions, this part is not available in the UK, however you can order pt no. 522959601 they may not have stock at the moment but at least you can order it.
If they did, why have high-tops?
They are for "heavy duty" (= dusty) conditions, where the filter surface will be partially covered by dust sooner. This means you can run a bit longer before you have to clean the filter.
It also means that you can use "flocked" filters, without worrying if the saw is getting enough air.
Edited by SawTroll
Anyway, even if you don't think it'll improve power, my 560 says otherwise!
Hi eddy it all down to eddy if your happy then that's great why worry about what do or think so when's the 572 I will leave 3 years get one like my 560 thanks Jon 👍👍👍👍
Stuff that, I'll be getting one the moment they hit the dealers!
Hi eddy you no when there when is it eddy summer this year and when you husky about new saws ask them about there new fuel I've given up any hope that was going to my XMAS GIFT FOR 2014 may be 2015👍👍👍👍thanks Jon
Huskys 'new' fuel is this magical stuff we refer to as aspen, with Stihl's launch of motomix in the UK, husky will just put the stuff they've been promoting for years in their own cans, as homeowners are more likely to use it (as it has the logo on). Having also seen the new husky catalog, there's no mention of the 572 yet... But that usually means an autumn launch!
It may well do that, if the saw is ported and needs more air, or with flocked filters are involved (they restict the air, compared to the mesh ones).
I just doubt it makes much (if any) differense on a stock saw and "normal" mesh filters. And there are of course some slight disadvantages with the high top covers....:001_smile:
