18" is a bit too much for a MS251. Sounds like your dealer doesn't deal with pro saws or users much.
I'd look online. Can get an MS181 with 12" bar for approx £220. If the Stihl delivery policy kills that with your location, screw 'em and get a Husky 135.
  • Replies 126
HI ALL i have a cheap ms180 that was my DADS saw good saw comes in just under £100 at £95 good thanks all jon :thumbup:
The 135 seems to rev it's little tits off compared to the 181. Fair enough it's got a bigger engine, but for the same weight the difference is noticeable.
The problems are the crap bar and chain, and I don't like the silly master control, or the fact it doesn't like to stay running or warm start.
My 135 is a lot better on aspen was a cow to start hot and cold on normal 2stroke some difference on aspen 👍
After reading lots of reviews I went for an echo 420 It has a 16" blade and cuts anything you throw at it, and with a 5 year warranty and a lot cheaper than a Stihl, you can't go wrong.
Glad you picked up a good'un :thumbup:
Bit of advice if I may? Spare yourself the mick taking, and call it a bar, not a blade.
Every other homeowner asks me if I sharpen my own blades, not their fault, but if you're using a saw with any regularity you should really know what the basic bits are called :P
I'm being pedantic anyway, please let us know how you find it.
Jon, I'm sending you a private message ...
Mine was like that till I adjusted the carb and it ticks over and keeps going now no problem. I bought a couple of spare chains on ebay and it's only an occasional use firewood saw so have had no problem with the bar. I have bought Aspen so I don't drain down after use but it did run just as well on petroil mix.
