I actually do work for a living Bob, thats why I suffer from it quite a bit, as I'm sure many many on here do. We dont have time to try new bits of kit and play around as the public purse does not pay my wages when I lounge around in the shade. :001_smile:
I work at self employed rate, not an LA rate. :sneaky2::001_smile:
practicing rescue is actually a h&s recomendation and should be undertaken and should be in your risk assessment and tbh 1 day per year actually benefits productivity as well as safety
you should make time and then you could maybe share the climbing with your groundie or at least have faith that a rescue could happen
You would be surprised how much work work we at our LA turn out compared to little self employed tree bods
The point i was making is that we have swapped around pre booked work for productivity and responsability:001_tongue:
  • Replies 69
So what are you going to do for the rest of the week or if the hot spell continues for a fortnight.
I don't believe for one minute you turn work round at the same rate as I do as a self employed person, what incentive do you have :confused1: ....go back to the yard early and get given another job to do ??
that aside i bit my self twice today with a silky ,nearly made a very rash judgement with the 200t and thought i hate this #~~~~~ job for the rest of the afternoon when i realised the ###### i was working for had not paid for the job from hell a month before, at this rate i wont be working tm any way!l
Today and yesterday were real killers in the heat. I've worn cat c up trees for the last 15 years and this week was my first in cat a - well timed!. I use a cambelbak and have frequent short breaks, I rehydrate as much as I can in the evening and get to bed an hour or so earlier and get a good nights kip in.
Most people haven't seen the result of heatstroke or heat exhaustion, as Dean says, its bad. I've seen a couple of lads nearly die of it. Slow down and take it easy fellas, its a bloody hard way of getting a sun-tan!
Some good advice on here.
Personally just slow everything down, apart from the fluid intake.
We don't get enough really hot weather here to make it an issue IMO.
It'll probably be p***ing down next week!
This is not hot ? drink lots of h20 but not all at once 10 litres min add some salt but only a small amount, only eat proteen carbs will rase your body temp and start at five work til eleven then go back after six if you have to. i worked in Aus up in the north that is hot ?
10 litres :scared1: you are over exaggerating surely?
