Lanyard
charlie
Anyone tried the sidewinder?
How much "tail" will coil up.
I took 2 strops up into a massive oak this week.. (Dead wooding) biggest I've done so far. Really tested my ability to climb and work efficiently in a very large canopy.
Although having the extra strop (teufelberger CE lanyard) helped, it also hindered me as well. Spent a lot of time untangling myself.
Next one (tomorrow ) I'm going to try and reduce the "clutter" in my system by using redirects rather than an extra strop.
I use a 10mm line for my work positioning lanyard, I used to always climb with a 10m lanyard with the tail stuffed into a hip bag, but have cut it down to 3.5m which I find is enough.
I think 11mm is consider good practice for a life line, I do not class a work positioning lanyard as a life line.
So when you're changing over anchor points what is stopping you from dropping out of the tree?
