Hello recently been using an 11mm rope xtc blaze and a 8mm op 90cm with the vt with 4 wraps 4 braids and it sometimes doesn't grip after tending slack?
Any tips?
  • Replies 27
Ocean polyester ??? Never liked the stuff for its inconsistency with a VT unless it's tied very short, I liked liros and roblon but they burn out quick.
Never looked back since AP.
I found the same problem, but like Steve said I put a twist through the braids and it worked a lot better.
I am on 8mm op and 13mm Marlow gecko. 3 wraps and 3 braids.
For some reason I never had the problem using the VT on my side strop with same set up.
Same on the side strop mate. Grips immediately, every time.
I think it's because it's tied short, and would be a PITA to advance on a main system.
Back on Beeline 8mm now after a love/ hate with OP and it seems to suit my climbing style better.
I've always found its a trade off between slick advancement and bulletproof gripping no matter what I use.
Tradeoff is right..... Love the sport-ness of the VT but also like the grippy-ness of the eyetie hitch.
Only ever used op, I like its durability.
Got a zigzag coming in a couple of days :):)
What do you mean by a twist? Does anyone have pictures to help. I might go back the old prusik if I can't figure out a solution haha
By a twist (my version) I mean;
Tie a VT but simply twist the rope from the ends or the eyes before attaching to the krab.
This creates more stiffness and changes the characteristics of the hitch.
I think this is what Steve meant but not sure.
I've also included a pics of the eyetie hitch which is an excellent alternative to the VT.
Hope this is helpfulImageUploadedByArbtalk1412934780.258271.jpg.9e61d5e38f94a0f83b74bc645c15ef12.jpg
