Shot out this morning to pick chipper up and forgot my steel jerry can for Diesel, so in my wisdom used a green petrol can to get by .
Rushing to beat the rain at site i grab A green petrol can (carry 2 green for mowers and red for mix) and DUNK it in the DIGGER ................. petrol ! .
Am still kicking myself now ,thought i got away with it but no cough cough stop.
2 hours that silly mistake cost me .
Ste
Get some two stroke oil mixed in with fresh diesel. Petrol wrecks injector pumps, make sure there's plenty of lube for your pump to try to limit the damage.
Cheers for that advice ,totally forgot about that ,have heard many people run a stroke oil in diesel .
Just put 50ml in a tank full .
Ste
Edited by IVECOKID
Ste
Refreshing to hear someone admit to making a silly mistake on a thread :)
Most of the time we try and make ourselves good !!! :) (I speak for myself of course). ;):)
Hope you sorted the damage.
I've done the same with vehicles more than once........
Its lack lubrication wrecks the injector pump
Classic scally trick when sacked
Pour bottle domestos into diesel fuel tank
Buggers lubrication and injection pump fails after he has left for last time
One reason for sending them straight home and paying them off
A bit of petrol in a diesel engine doesn't do much harm, diesel in a petrol engine isn't so good.
I know nowt about chipper engines but doubt they are too picky.
Mercedes even say to put a bit in (upto 10% I think) in winter.
Petrol in a diesel engine will do far more damage than diesel in a petrol engine. It will ruin the injectors, pre-ignite under compression and then trash the rest of the engine.
I wouldn't like to say which is worse but petrol actually resists pre-ignition, higher octane more so,whereas diesel ignites at a lower temperature. So for a premixed engine you want high autoignition temperature and low flash point and for a compression ignition engine you want the fuel to start burning as soon as it is injected.
I suspect diesel would not harm a petrol pump but neat petrol will not lubricate the diesel pump.
Diesel in the petrol engine is likely to detonate if it runs at all and this will soon ruin the engine.
