325 to 3/8
Supernube
The speed cutter...also a full timer obviously...was using a 560 xp ..3/8 with 15 inch bar...but unfortunately I didnt get round to asking about sprocket etc.
I think I am going to go for the 3/8 on a 15 and try both sprocket sizes...only as a learning curve for my own knowledge...I have always just used the saw as they came..never even knew about the different sprockets and speeds etc...again..lack of knowledge :blushing:
Anyway...thank you all for your help...I will let you know how I get on.
Thank you
  • Replies 44
What saw did the speed cutter at the APF have ?
I'm guessing it was bigger than a 560 and he was running 3/8 pitch with lowered depth gauges and needed the higher profile 3/8 cutters for chip flow.
With a 560 I would stick with .325 and run 8 or 9 tooth sprocket.
3/8 may give a faster chain speed but 9 pin is 9 drivelinks which is more cutters per engine revolution.
First you need to know what sprocket you have - probably a 2 piece " power mate " type sprocket with a separate clutch drum and drive rim.
There are 2 sizes of rim sprocket available for this saw with different sized drive splines - small 7 and standard 7.
The small 7 will take 7x325,8x325 and 7x3/8 rim sprockets.
The standard 7 will take 7x3/8,8x3/8 and 9x325.
Assuming you have a 7x325 drive rim your first thing to try is a 8x325 rim.
If that is too slow change the clutch to standard 7 and use a 9x325 rim.
It's funny you should question that, the guy with the 576xp was running .325 on a 9t, as the racing bars are, all but one, in .325 and d009 mount
Thank you
For a learning curve, you might as well start with upping the (undergeared in my opinion) sprocket on the bar and chain combo you already have. A lot cheaper to start with :thumbup1:
If it was all about chain speed they would be running 8x404:001_rolleyes:
I sometimes run my dolly on 9x325 with a 15" pixel bar and chain.:thumbup1:Must get some 50 guage RS :biggrin:
My 365 spends most of its time on 8x3/8 with 15"bar and RS chain.
Where can you get a D009 in 325 ?
I was thinking would have to change the nose sprocket on a 3/8 bar to 325.
8t .404 is discontinued, and very damn rare, trust me, I'm after a rim in that size!
And regarding the bar, husky make them, but it's difficult to get the part numbers! They come in 14, 15, 18 and 20 inch bars only.
I have a custom made 9 tooth .404 and a 9 tooth 3/8 both racing sprockets if you are interested ?
Not going to get into the what's faster debate - but I have the 15" Sugihara bars in all guises in 15" found here (so as not to upset the guide bar selector!).
Products for the category: Special Offers
:001_smile:
I think the reason when these type of threads throw up a lot of answers is because there is no right answer!
Soooooo many variables - what wood your cutting/what chain you use/how you sharpen/is saw modded/is saw running correctly etc etc.
You change just one of the above and it could be a different set up that is quicker.
I would set yourself up with different drive rims and see what works for you.
Also the chain type and how it is sharpened - experiment with both Stihl and oregon chisel and micro chisel (x4 diferent chains) to see what works best...
:001_smile:
Haha! That would be interesting on the 090!
Did the maths, I've uprated my 090 to 8k rpm, 9 tooth is going to put the speed to a lovely 23.5m/s. This may not sound a lot (8t on most modern saws will put the speed over 24m/s) but what has to be remembered, is that this series of saw was designed to pull 10 feet of blunt chain through 20+ feet trees!
hello i got a question is the sachs dolmar 116 SI a K095 OR K153 bar mount they look similar spacings but the chain adjuster hole and oil hole seems smaller on the K153 bar :thumbup:
