New stumpy - which one??
Al Cormack
I have a feeling my 10 year old Danequip stumpy is 'beyond economical repair'.
Its need a new engine as using as much oil as petrol nearly, some of the front guard area needs patching/replacing, bearings need replacing after getting tangled up with a one ton bag that was buried (ripped the bearing carriers right off!)
Almost a complete rebuild!.
So, to my question, if this is the case what do I replace it with?
I like a grinder that can go into back gardens through side gates, any big stumps I hire in a machine, and needs to be self propelled to go up ramps into the back of the lorry.
Suggestions gratefully received.
Cheers...Al
As you've realised that's a fairly simple repair probably only about £2500 ish or less if you fit the new bearings and engine yourself, which is pretty easily done. What happened with therein bag? Mine has eaten a few with no ill effects other than The 30mins wasted cutting it free!
