Me again..haven't posted for at least 2 years and now 2 in one day. My trusty 18" Hitachi CS45EL is dying. It has performed really well over the past 3 years and has never been thrashed and has been lovingly looked after. I have recently been fortunate enough to have been offered some 'woodland management' at a good remuneration but the above saw is now definitely struggling at being asked to cut fallen oak of 18" diameter or more and other similar hardwood. It's just not man enough and is not up to the task. I've researched saw after saw and I'm going round in circles - just when I think I have found the ideal 'pro' saw I find a couple of shite reviews on it. As it seems that I need to spend at least £500 (or do I need to up my amount) I would like to think I'm going to get something that will start, run and cut well and not be too heavy as I'm getting on a bit now, 5kg ish would be a benchmark. It would also be nice if spares were readily available and that it would last for a few years. Am I asking too much? Can Arbtalk forum members point me in the right direction please and tell me which saw to get?
P.S. Definitely do not want tool-less chain adjustment type cack.
Edited by BobbyDee
Your choices are either the husky 545, 550xp (both 50cc), 555 & 560xp (60cc), or the 365 & 372xp (70cc)
Stihl: 261 or 362 (the Stihl 291 and 391 are pants)
Or an older model 346xp, 357xp or 362xp
Stihl: 260/026 or 361, 360 or 036
Or what ever the echo equivalent is...
TCD will suggest dolmar, but euro dolmar have no dealer or parts network in the uk (all has to be shipped from Germany) or a USA import, which are not CE marked, so about as legal to use as a ported saw by HSE standards.
An stihl 261 no later then 08/09 after that not that good or take a look at the new 261 and may be so with the heated handle version:thumbup:
Soz that should have been 260.
On the Stihl side, if you can get your hands on both, I would compare the 260/261 and the 360/361. The latter is heavier, definitely, but will be much quicker through the larger stuff, particularly where it's hard, so it's a trade-off between the extra weight and the extra power. I would try the 260 with a 14" bar and the 360 with a 16" or 18" bar.
Alec
Are Echo worth considering then?
The CS600 looks good on spec.
Have a look at the 261 cm heated carb( I think ) but deffo heated handles. Spot on for those long winter days in the woods. Bout £600 with 18" bar:thumbup1:
Alec
My thoughts to. Personally I would even recommend the 260 or 360 over the 1 series.
Good allrounders, parts always available at sensible prices and within days if out of stock.
Although im a Husqvarna preference person I don't rate the 550/560 in the reliability stake and parts can be a pita sometimes taking weeks and more expensive.
