Stuck bolt!
richy_B
I presume you've tried the obvious; turn the bolts clockwise to partcially tighten, before attempting to loosen.
Together with above but a good soak with penetrating oil first, leave and then quick blast with a bit more, before attempting the tighten & loosening.
Heat with decent blowtorch, then ratchet the thing off. If it goes all honey-shaped. You'll just have to drill and Helicoil.
Edited by TGB
Just put a new drum on it
You're sure it's not a left hand thread?
I am not familiar with the LM162 but many commercial vehicles have LH threads on the NS wheelnuts. Fooled me completely when (as a 17yo) I bought a twin wheel Transit!
If the nuts really are that tight you're going to need to replace the studs (at least) anyway so shearing them off really isn't such a problem. I'd go for a 3/4" or 1" drive socket and breaker bar and just go for it.
I serviced Ifors for 5 yrs, it's not going to be a LH thread. Agree with those who have suggested hitting the bolt with a hammer, a shock works better than pen oil in this application. Same goes for when using a breaker bar, give it a good jerk. Also, heating up
the drum will not do your bearings one bit of good. Put the wheel bolts back in with a bit of copper grease on the thread to make your life easier when they next have to come off.
Sent from my D6503 using Arbtalk mobile app
Yep, I`m not suggesting a heating to the point of roasting the bearings, but a bit of heat applied quickly along with a whack usually works for me, but it`s the quick precise heating with the oxy that gets the two different bits moving and the separation lets the oil penetrate into the crack. In my work I couldn`t be without oxy-acetylene, cheers
