found on an acer
if it is honey fungus would the appropriate action be to remove the tree before the fungus spreads and weakens the tree?
found on an acer
Joseph,
For future ref. Honey fungus is a toadstool, it has a little ring on the stalk just under the cap. The underside of the cap also has elongated gills, slit type structures which release the spores.
This is a bracket fungi, a polypore. It grows sideways from the trunk and the underside has pores, tiny little holes for spore dissemination.
Another difference is the position. Honey fungus is a root decay fungus so is usually on the ground although not always. Polyporus is a sapwood exposed coloniser found on wounds like this one and usually higher in the tree.
Hope this helps
...and, not withstanding that's a mighty big wound / cavity, the position of the brackets may indicate the fungi is active mainly in the dysfunctional wood (see Mattheck's Manual of Wood Decay in Trees) and not of such structural significance in the early years...so to speak.
I hope this is good advice but doubtless others will let you / me know if not.
Good post..:thumbup1:
Paul
