50:1 petrol mix ok to run in a lawn mower?
AlvinD
The odd accidental filling wont hurt at all, as others have said, it will just be a bit smokey.
But its certainly no treat for the upper cylinder, which does just fine on the standard lube past the rings.
Frequent use of 50:1 will not only foul the plug, but also build up a thick layer of soft, black oil deposit on the piston crown and around the swirl chamber. This will raise the compression and lower the combustion efficiency.
The exhaust muffler will also clag up in time.
