Because it's too long!
ours is exactly the same , it does block on wet stuff ocasionally , is that the reason for shortening them??
  • Replies 38
just looked at the photos of the back of the mog and id say the doors at the back are way to low, on the one at work the are about 3/4 high and we can fill to the brim, that said greenmech raised the height of the chipper chute at the turntable by about ten inch. i have seen other mogs with a notch cut out of the doors i would say that is the best solution.
carl
You could always increase the distance between the truck & chipper therefore decreasing the amount of chip that blows out.
Much much simpler :)
how would you do that??
I was being ironic :)
On phone so no wee roll eye faces.
Tbh the way your chute angle is from the chipper isn't helping, this is going to create a splatter pattern of chip, a nice swan neck is what your after
Speak withGM they will calculate the minimum length of spout to stay in compliance with the CE standard it was built to
It's not mine and it wasn't built to a CE standard, they don't produce standards for chippers or anything else.
The length of the discharge won't be an issue for CE marking but the height would be, you can get the height you need without all that length.
