vests are great in the heat!! until you get skin cancer...and lets be honest, 99% of tree guys arent going to be wearing sunscreen the whole day.
  • Replies 75
Oh to be you, we cant wear sunscreen all day because the rain would wash it off:laugh1:
haha, fairpoint 'quip!
but for any uk climbers off to the nz summer- your skin will burn like a crisp so wear sunscreen and use it a lot. SPF 30 minimum.
Long sleeves in the heat stops your skin cooking, I like hi vis t shirts personally like the ones arbor wear make or underarmor I think when speaking to a client when you arrive on site you should have a shirt or a t shirt on, then change when work starts etc i just get burnt with a very on personally
Sent from my SM-N9005 using Arbtalk mobile app
We use full hi viz singlets, t shirts and long sleeve although the singlets are getting less and less of a look in with the harsh sun in NZ. The full sleeve shirts are transit compliant so we don't need a hi viz vest when working on the road which cuts down on weight and heat. All the shirts are made from the wick away, quick dry material and are pretty good at not being too stinky. They also look quite smart compared to some of the local contractors and they comply with our arb codes of practice.
Sent using Arbtalk Mobile App
The tight fitting neck would do me in .
You can unzip them and if you are climbing they are great at keeping sawdust out, because we all know that once its in your shirt its going to migrate down to your undercrackers:001_huh:
