Small Tracked MEWP
jjll
Sorry I'm in Gloucestershire.
I would get away with a 20m reach, I'm assuming smaller reach means smaller machine in terms of turning length???
The narrowest part is a 3ft gateway and then there is an immediate path way about 3-4ft wide but has a low wall either side about 1-2ft high.
You might struggle to find one to fit those specs, but good luck with it.
you could try a Cela dt15 only 800 mm wide
