what machine do I need?
Al Cormack
This is the garden. It a lot steeper than it looks in th photo. Everything down the right is coming out a the massive conifer at the bottom.
He second photo shows the base. Those bigger stems are 2ft dia + and approx 60ft high!
I'll be dead after carrying that lot out by hand!
Could try the winch but it will be going all day...
  • Replies 55
HI AL can you use dumper or A LOADER LIKE IAN FLATTERS has got thanks jon :thumbup:
bonfire springs to mind :biggrin:
Fair dos I'd want some help on those. If you can fell the one at the bottom, I reckon they'd winch up. If you section felling, it would be a slow old job!
Cheers
Mark
Sent from my GT-S7710 using Arbtalk mobile app
Get three guys dragging. Least damage and probably the cheapest option..
I did wonder about this, but it has to go up hill not down, so would need a winch or something to haul the loads up, could be a bit to complicated.??
Sky line is best done uphill then gravity can act as a brake at the drop zone. Lining downhill can be a bit sparky as the load is less manageable and gravity makes it quicker!
Can you access through the rear (she said:sneaky2:)
