Out of Aspen - trying out STIHL MotoMix
morten
  • Replies 60
Yes and ended up spilling more than ever as it's the same crap design as the husky cans that after a few days don't click closed when you pull em out and I had a saw chew open a soft plastic can on the way too a job, lucky only lost about a litre.
Like said 25ltr and little tap would suit me better just for convenience.
sent while pretending to do something important on my mobile.
Hi,
This is the first I have herd of A FillPartner failing. Did you ever use it for normal petrol?
The 5 litres have to be made from this type of plastic to be recyclable.
Please PM me
All the best
Eddie
Hi,
Please PM me
All the best
Eddie
Hi Eddie, I drop by your stand on Friday and have a chat.
John.
So your saying if I use aspen im a lot healthier? Bs .....a few fumes over the day makes little difference compared to what we breath in to start with plus a lot of arbs smoke so its pretty pointless to worry a bout a few petrol fumes.
Sent from my GT-I9300 using Arbtalk mobile app
Hi IC,
I understand what you mean that switching to Aspen will not save the world and compared to other sources of pollution the use of chainsaws only produce a tiny amount of emissions.
The point is your exposure to Benzene and the other 100 plus toxic chemicals contained in normal pump petrol.
If you can smell the exhaust of your saw then you are breathing in toxic fumes.
Have you tried Aspen?
For a fair test a machine that has used normal fuel and 2-stroke oil needs 2-3 tanks of aspen to burn off the old oil in the exhaust and give you the much nicer cleaner exhaust from Aspen.
If you ever use a saw in a confined area or hedge cutter you will notice the difference with the first tank.
Eddie
