Hello,
was having a chat with someone the other day about thinning out some broad leaves for firewood. Nothing too exciting, a bit of ash, syc & oak. Relatively straight lengths that could go through a processor but we were debating the best size lengths. The kit for extraction plays a big part of it but generally speaking what do people go for? 2 metres is probably a bit short but you could ensure it was good straight lengths, 3 metres and straight might be far more difficult. 2.3? 2.5? or just a mixed bag of lengths as long as its straight.
What would you go for?
2-2.3 = two bays on most forwarders or 2.5's bigger forwarder although on small forwarders back bay of 2.3's can be hard to load - keep from falling off the back.
3.1's plus make less work for forwarding but as you say higher proportion
of bends.
Maybe a mix of both.
I much prefer cutting chip to 2.2 or 3.7 but the latter are harder to lift onto a Japa 700 (no fandangled log-deck here!)
Then hauliers want to optimise load cubic capacity in relation to weight...
Edited by TimberCutterDartmoor
Hello,
Put curly bits in the stack and the haulier is likely to push a sharp stick in your eyeball. :) Cant think of anything worse:thumbdown:
Bob
