i do believe that there are versions of danish oil that can have a varnish type material in it but most are just 50% tung oil and a mix of other natural oils.
for an indoor table it would be perfect to get that natural look without the obvious look of somethings been applied...
  • Replies 30
I've never seen a Danish oil that didn't contain Varnish. I've just finished a picnic table that I didn't realise was an oily hardwood. The wiping varnish has lifted and I will have to strip it down and seal with shellac first. Oak and others are fine but those oily tropical hardwoods can be really difficult.
I shall strip, sand then degrease with acetone before coat of shellac. Sand back when dry and recoat shellac before varnishing.
Very surprised by this.
I have used Danish oil and teak oil on oily timbers like Iroko without any problems but this was on internal work. So deed it peel off?
I would try Liberon finishing oil, or danish oil , turn the table upside down and do a few test patches on the underside of the top to see how it goes . Both oils are fine but LFO is a bit easier to work, less sticky , and easier to clean of your hands !! Why is the table unfiished ? do you want a matt , satin or gloss finish ?
I just want it to look about the same as it does now. It comes I fished as they claim it's so dry I two t stain or some bs I did t believe. I will post a picture shortly .
i've really only used danish oil so have no experience of others but danish will do what you ask just enrich the colour a bit.
are you sure that's teak? looks a little red.
That's what I thought, Yew possibly?
Sent from my Nexus 7 using Arbtalk mobile app
