For that budget go for an echo or a Honda. You won't get a stihl for that money. I use a Honda and echo regularly and like them both. The Honda 4 stroke engines are very efficient, easy to start and quiet.
for that money get the Honda 435 will do everthing you want it to do aand more. i use mine every day in summer does not miss a beat. 2 year warrenty.
the bump and go on them are a dodle to feed
the blade works well on big brambles. smaller ones i just use the line.
recomended line is 2.4mm i use oregen starline 3mm and works fine. 4 stroke so no mixing.
the harness is good but i bought a husky pro harness as more comfy.
and just within your budget.
i have the 425 as well but a bit small for what you want to do.
out of your budget but walk behind strimmers do a very good job for doing large areas. have bigger line and munch trough most things. DR is the best one
  • Replies 52
A 2-mix FS-70 is £70 less than a 4-mix FS90, but the same power.
The FS-70 engine is great, but it's a flexi driveshaft.
I'd be tempted by the Echo TCD posted- £30 more but a solid driveshaft. Quite a bit heavier, but also quite a bit better vibration figures. Throw in a 2-year commercial warranty and that looks very attractive.
OP, where are you located?
Seriously; ignore the Echo weight figures - they are nonsense. I went from a 6 month old Stihl FS85-R to the Echo SRM300 (so higher cc) and the Echo is a lot lighter - it is extremely light in fact. It is soooooo smooooooth too. The Stihl was seriously shakey by comparison too; just rough. I'm not saying this because I'm a fan of Echo; I'm a fan of echo because what I say is true.
To be fair, the Honda isn't a bad machine, and was pleasant enough to use.
I'm not so sure you wouldn't be better off with a second hand professional machine such as an FS460. The full length anti vibe makes such a difference, I wouldn't use a bike handle strimmer without it now. You can get an FS460 for £300 second hand, in fact I have one I would part with for that.
+1 fs460 I got mine 2 years ago and have never looked back it is a beast of a machine starts great runs better and chews through undergrowth like nobody's business, used it with the shredder again yesterday and love it, I now have secured a third job on the same property to clear >1 acre of bramble filled field!
A slightly smaller fs would probably do you, but I love my fs 460 (although I have 2 other machines of different sizes for different jobs!)
I believe the Husky machines do or certainly used to have "cruise control" which meant you could set the revs lower and just plough on, I wish I had it on the stihl but the lack of it doesn't bother me enough to change.
And yes I use my strimmers on a regular basis as that is my business, I do gardening/grasscuting rather than tree work.
The Husky does have a tortoise/hare button but I never use it . The 545RX is a loony but you control the throttle ! ......
My fs55 with the bullhorns seems pretty suitable for me and I think there around £300 ish , defiantly worth getting the harness aswell saves your arms on those larger jobs .
