I'm looking to buy my first strimmer / brush cutter but don't really know where to start.
I need to clear around an area of woodland of thick brambles, maintain close cut grass around half an acre of recently planted orchard and fruit bushes and maintain grass paths at an allotment.
I'm keen on the machine being as quiet and efficient as reasonably possible. I also like reliability and warranties! I guess some kind of blade will be needed for the brambles and a line for the grass?
Could someone point me in the right direction with a few recommendations and point out anything I should avoid?
Thanks.
  • Replies 52
We have. A stihl fs 310 and 410 not shure if the 310 is still made. But there good quality have a bit of grunt for brambles they offer a years profetional warrenty i beleave
tri stars are good for brambled. Mulching blades are avalible too havent used one tho
You can also get blades for grass but they all come with a line head i think
If you want power and half the vibration of normal strimmers, you need to look at either the Stihl FS310 + range or Husky 545 (I think).
These have full length anti vibration thingys.
Thanks all! Could someone point me to a quick primer on 2 and 4 stroke applicable to strimmers and where the Stihl 2 and 4 -mix engines fit in. Budget wise I'm looking to spend up to £300, unless there's a very good reason to spend more.
For that budget go for an echo or a Honda. You won't get a stihl for that money. I use a Honda and echo regularly and like them both. The Honda 4 stroke engines are very efficient, easy to start and quiet.
Forget 4-mix for a start and im sure some others will agree, prob not all. You have to scream them as no low down torque and can be problamatic.
Personally I would go 2 stroke but that's just me. Cheaper, easier to fix, more straightforward to work on, cheaper to buy and usually a bit more go but a little thirstier and I guess you don't need to mix up fuel. Most of us prob aren't bothered about the fuel mix scenario as we already do it for chainsaws, strimmers hedge trimmers and alike so usually have it on tap anyway.
Second that. Avoid 4-mix.
