Maybe the top krab on the SJ. Gives more distance for the ascender to move up the bungee giving a bigger step. I can't think why it wouldn't work but I'll give it a go this weekend and let you know.
J:thumbup1:
  • Replies 74
J:thumbup1:
Great stuff buddy thanks... I fear this will end up costing me £130 :001_rolleyes: but could save me getting popeye leg from the single pantin :thumbup:
The only issue I can see with using the top crab is the elastic clashing with the leaver on the front, say for example you wanted to drop a few inches because you'd over shot where you wanted to be for a second... I know you could undo the clip and put it back on but would be better if it could stay on if needed.
Could you not use some pull cord, make a mini prussic and attach it just above the splice? Then clip the elastic cord to it. So it runs either side of the lever
Worth a try. Ill be getting one to use with the H/C and spider jack 2.1dia
And thanks to Gerbut. The loops arrived and the small one is perfect😊
Excellent 👍
Right. Hopefully you can excuse the white legs. Chainsaw flip flops are always added to the risk assessment.
The pics are as clear as I could get with all the gear in one go.
And I nearly forgot the pic of the loops.
