diesel roller on vibrate or a whacker plate
its best to roll when the ground is damp if you roll when its dry there will be very little improvement roll when its wet & you will do more damage than good!!
Add a mix of fine sand to compost and augment the 'pot-holes' with that and allow the grass to grow through - hey presto level ground!
I'd go with this suggestion if I were you. :001_smile:
