Not the usual piece from me but I have been experimenting with soft wood and casting it in resin.This was a piece of Elm with a hole of rot running through it,used the wet rot hardener to stabilise the wood
The wood is encased in the epoxy resin and put in a pressure chamber,than when it's dry I turn it on the lathe.The Epoxy turns beautifully
The pressure chamber is just to make sure there are no air pockets and bubbles
