stihl or husky pole hedge trimmer
Tom Hall
Hi all
looking to invest in a pole /long reach hedge trimmer, which camp should i be looking in?
I have used a stihl one but never the husky, and i find the stihl one to be very good to cut with and robust, but a pig to start and the vibrations are horrific, and they seem like the pole saws to be awkward when it comes to fuelling, awkward to remove the cap the have a tenancy to cockle over when you depress the fuel can in to them?!?!?
so any suggestions please:thumbup:
Echo here - good build, low vibes, the foursroke Stihls are.............interesting to maintain and they will need maintaining.
Two stroke is such a simple technology - why buy a fourstroke - too much to go wrong!
Ah but it's not a four-stroke though is it? It's a combination of ALL the bad bits from a four and two-stroke!
The 4-mix are seriously shockingly bad! Maintenance involves the carb tuning, engine timing, valve clearance, checking the cam for wear, blah, blah, blah! I refuse to work on them! Fiddly damn things, there's a dead one at work where the valve dropped into the cylinder!
Sent using Arbtalk Mobile App
Aaah, but it is Stihl is it not.
So of course it will be forgiven all its faults.
Because its Stihl.
Why are people so blinkered?
Because its Stihl.
My blinkers go on when I hear the words 'Ed, can you take a look at this'
