  • Replies 27
They don't, unless you started doing it - then you have to follow up.
What needs to be greased now and then (but not weekly as the manual says) is the clutch bearing - and that is really easy on the Husky saws, with the grease gun, and the hole in the end of the crankshaft.
I never had an issue with the stock ones, except that it took some time to figure out how to refill them....:001_tt2:
Hi
Could that be attributable to the significant number of 261 clutch bearing problems? being as Stihl dont advise greasing. Ive decided to swap my Stihl clutch bearing annually & grease it as per the Husqvarna advice.
Just a thought
N
Where do you go to get a gun that works,mine is pants,skiddy pants too.
Never greased one yet. Grease collects all kinds of crap that will bugger the sprocket unless you re-grease and shove out the old every time you re-fuel.
But how does it get in there ? Please explain as I can't see why more dirt should get in just because grease is present.
The issue is that the dirt sticks to the grease, I assume.
Hi
Just a thought
N
You may well do the right thing, and don't really understand why they don't advice the users to grease the clutch bearing now and then....:confused1:
Maybe they like to sell parts? :sneaky2:
