piston stop (what to use?)
wicklamulla
well i usually use the black plastic one that was supplied with my MS200T, I also use it on my Husky ground saws. But i bought another type yesterday which is made from natural coloured nylon which screws in place instead of a spark plug and keeps the piston from moving. What say ye, are these ok to use or can they damage the piston or bore ? kindest regards, KEN:thumbup1:
  • Replies 23
Of course they are ok, thats what they are for. Yuu can even get metal ones, a slight scratch on the top of the piston wont hurt anyway, my 066 has a big dent in the top of the piston where we really struggled to get the clutch off recently, its fine though.
An impact gun works well too, sometimes no need for a stopper!
Pull cord hear aswell.
Main thing with pull cord is to not get it stuck in the exhaust port. That's about it.
Never really like piston stops to be honest, heard too much about them breaking and taking forever to get out the cylinder.
I have never liked the metal ones either. They do damage the top of the piston. And when metal is dented it has to push it somewhere. If that makes sense. Make a dent in metal plate and you end up with a rise in the bottom. So dent a piston and it has to push the ally somewhere. Plus it only takes a small bit of broken metal to cause serious damage.
Cord here too, but don't use anything frayed, as I found out to my cost. The frayed bit happened to end up near the edge and jammed between piston and bore - fortunately it was a big, heavy cast iron lump (Villiers engine on a Teles) and due force was applied, but it could have been terminal on a modern saw.
Alec
Listen to Rich and Alec, I have had a couple of saws with fractured piston crowns when someone has used a screw in type on an engine with a plug hole that isn't at the very top of the combustion chamber.
The Stihl one us generally very good and rope with saws with clutches on very tightly but make sure the piston is covering the exhaust port when you insert it otherwise you may get issues:thumbdown:
A typical pneumatic impact gun on a screw in metal stop is brutal IMO and a good way to fracture the piston crown - you aren't working on a lorry :001_rolleyes:
tanks everyone. Spud i tink he means to use the impact gun on the clutch to spin it off and not the piston stop (i hope) !
