big gas bottle under tree.
David Dobedoe
We were looking at a tree removal job yesterday. Buildings and other things underneath that must be protected/looked after.
Included is a large static gas cylinder, the type gas is delivered to with a lorry. Obviously don't want to damage it and care need to make sure we don't drop anything on it.
What other precautions are required / sensible. Does it need to be empty, moved or is it reasonible to work above it full?
Thoughts please. Thanks in advance.
David
I had a fair size ash in a similar predicament. Rigged everything down on the opposite side of the gas tank. Luckily I could work in next doors garden to do this.
You could use some pieces of ply over the top to protect the fragile bits. The tank itself is pretty tough.
