Hi again guys, the bar from my 576xp didn't fit the 9010, how to I get hold of the 8mm bar mounts ? D009 mount I think
Sent using Arbtalk Mobile App
What stops it from fitting Ed - can you get any more pics to show what is not fitting where?
  • Replies 65
Hi rob, the two 12 mm round bits at the bottom, ImageUploadedByArbtalk1395037398.580527.jpg.89e830aa5fb1674ab86a3b646673496f.jpg
hello ed i ground my studs off with a lathe down to the right thickness but if you take them out and go to a dealer or find old scrap saw and take them out there is a 8mm thread underneath that flange 100% cheers
Hi rob, the two 12 mm round bits at the bottom, [ATTACH]151507[/ATTACH]
Thanks Ed - so it's not a straight D009 mount - but would be if you ground off these bits... still a bit of a hassal - I wonder why Makita choose to have these on here in the first place?
To be a pAin in the bum, do you supply d009 mounts rob?, or know anywere that does?
Anywhere that does bars for the 70+cc huskies
with the 8mm studs the bar iam using is 320RNDD009 100% the only reason i changed the original bar was because it was a solid nosed bar so i was trolling ebay us and came across this 32'' oregon bar chain combo it was listed as fitting solo 603, 690, 694 and dolmar 7900, 7910 9000 , 9010. knowing that the solo 690 and dolmar 9000 was the same saw but after doing some research the american models had the 8mm bar studs not the 12mm studs that we have in europe but one plus that came out of this mix up is i got a new dolmar bar for the 133
