  • Replies 20
In a nutshell if you have room to get 1 in yes if not no! we find that its great for moving brash/logs carrying tackle round but 9 times out of 10 most garden gates are so narrow when youve got a decent load on it wont fit through tight bends or corners unless its cut up and stacked on the trolly you cant get round. the tyres that are on are pap i replaced ours with solid rubber ones as the others punctured easily. comes in handy defiantly, well built but they aint cheap :thumbdown:
We use it for hauling logs on-site as stated above stacking brash and pulling through narrow or bendy paths does not work that great. It is pricey but call around to different suppliers to get a good deal ;) I would not give it up as it is valuable and extremely handy as it saves 20 trips carrying one log at a time and cuts it down to 2 trolley loads :D
I'm not, just ordered mine for a job iv got coming up in a graveyard with over 80 trees to work on and pedestrian access only so long drags but on paths, in theory this 1 job could pay for it if it's as good and saves as much time as I hope
sent while pretending to do something important on my mobile.
Was very handy for a job few months ago :-) ...... looks a bit unbalanced because I was about to tip the and roll the trolley, saved a lot of ball ache and ringing up :D
