Entec Kohler engine won't run properly
Andy323
Hi lads,
Wondering if you could shed a little light on my problem. I've got a entec chipper with a petrol Kohler 22hp a think, it starts up, runs fine for a few seconds buts the revs lower and sometimes cuts out. I've had the carb cleaned in a proper tank and the in line fuel filter is clean, just not sure what else to check?
Any help greatly appreciated
Cheers
Andrew
Hi lads,
Cheers
Andrew
It sounds like it needs the ignition coils doing I had the same problem with my 25 hp and if the coils are same I have a brand new set spear.:001_smile:
it sounds like it needs the ignition coils doing i had the same problem with my 25 hp and if the coils are same i have a brand new set spear.:001_smile:
ditto ash01 had same problem and had to replace one of the ign coils
to get it to run upto speed more power etc
MAY BE BEST TO TEST THE SPARK STRENTH WHILE ITS RUNNING PULL A PLUG LEAD AND LISTEN TO ENGINE TONE CHANGE IT MAY EVEN PICK UP AS THE SPARK SHOULD JUMP FURTHER AS THE PLUGLEAD IS PULLED AWAY IF THERES NO CHANGE THEN THAT COULD BE YOUR FAULT GOOD LUCK HOPE YOU GET SORTED SOON
Edited by predator
you beat me to it
