Below is a very simplified diagram. I have been looking through lots of pages to find out the forces involved at differing points on this pic, but nowhere I have looked explains the force at B. By my reckoning, A should be working as would a fixed point in a 2-1 pulley system, the weight should be working as the pull/effort in the set up, which would make B the effective weight of the pull/effort x 2??? Is that correct?
Please note that although the pulley at B is fixed to the tree, it is the force on the tree that I want. thanks in advance.:blushing:
  • Replies 26
Popular Days
If one ton is suspended from the pulley, an equivilant force is acting on the fixed point to keep it motionless.
So you are correct - a one ton load on either leg will place a load of 2 tons onthe pulley - doubling it
