Hello good folk of arbtalk!
I have a problem with my Makita napsack blower, it starts fine and runs well for about 5-10 minutes and then the revs won't pick up and it dies.
Its a few years old and I only got it a few months back so don't know its history, but I did fit a new spark plug in the hope it would fix it:001_rolleyes:
It has fresh fuel (2 stroke) in it so I have eliminated that issue.
Can anyone help with a remedy please?:confused1:
Thanks in advance
Edited by normandylumberjack
spellin
Weird things ignition coils, nephew had a moped that would run for so long then only run on tickover so I obviously thought it was fuel related and cleaned the carb out three times with no improvement till I fitted the coil from another just as a last resort and found it cured it permanently. I also thought it might be air locking due to tank vent but it did it with the cap off as well.
Tried the fuel lines etc, washed the air filter, looks like its the coil.
So had a look online and a replacement is £112! Can't belive it, already purchased a flexi pipe and harness for it, on top of 120 euros I paid for it. Gutted:thumbdown:
Will have to pick up a new stihl when I'm next in the uk.
You can get a drop in compression when an engine gets hot, if it starts at a low 130psi, when it is warm, it can drop to 115psi and stop it re-starting hot.
Other than that it may be a tank vent, fuel issue or ignition coil - try closing the gap between the coil and the flywheel - had a MS460 that would start and die when hot - found the gap too large.
It isn't always the end of the road and don't give up easily on anything:thumbup:
