Well, there you go!
By the way, the GC engines tend to eat spark plugs too, so get one with the gaskets. And an air filter.
Thanks for your help, hopefully will get it sorted.
Can anybody tell me a basic spec for a sit on 12v battery that'll electric start a briggs 11hp on an mtd. Is there a formula/ratio/connection between Ah's and engine size/hp for the future? Cheers.
Sent from my GT-N7000 using Arbtalk mobile app
It really depends on the size of the battery tray.
Hi Barrie - cheers
i can modify the tray to suit - its just that 24Ah upwards which are advertised as sit on batteries all seem around 35-40 quid mark.
toolstation do a 12Ah 12 volt for 28 quid - i'm not sure how you measure cranking power in a battery and whether there would be enough oomph in such a battery
Spent an hour cleaning the carb up, replaced all the gaskets, lubed and adjusted the cables, replaced the spark plug and cleaned the air filter - it was pretty new and sharpened the blade.
Runs like a dream.
Thanks for the advice.
Matt.
Hi Barrie - cheers
I would certainly not fit a 12ah battery Mike. False economy, even it if does the job, which I doubt, it will not last.
thanks a lot Barrie. Question answered. Good brake spring tool tip vid btw :thumbup1:
My parents' MTD 165/E has a 20Ah battery (NUMAX Y50N18LA2). That's with a Briggs & Stratton 16.5hp 694cc twin cylinder engine.
