Autotune vs M-Tronic
Pinkfoot
  • Replies 22
M-tronic is the old autotune, it's literally as simple as that, stihl have the tech on lease from husqvarna.
Sent using Arbtalk Mobile App
I'm not sure if I can believe that because m Stihl dealer didn't tell me this when I asked him that question in Saturday.
Hahahaha!
Sent with my iPhone from me, to you!
Husky's 'Autotune' is the newer stuff yes. But Stihl's 'M-Tronic' is the easiest to live with. Both H' & S' state calibration when new, plus recalibrating when changing altitude by 1000ft, changing an air filter, change of fuel type, etc., (Whether either actually need recalibrating at such times, well the jury's still diliberating.)
Calibration Prcedures
Husqvarna
Run the saw at full power, with bar fully buried and under load in "thick log" for 3 to 5 minutes, without letting the revs. off at any time.
Stihl
Remove bar & chain, replace clutch cover for safety and run saw at idle for 30 seconds, without touching the throttle. Then switch off and refit bar & chain.
Which would you prefer to live with?
Husqvarna
Stihl
So, your question is would I rather carry on and do work with my chainsaw as it tunes itself, or fiddle with it and get no work done for a couple of minutes? ;)
Husqvarna
Stihl
The first one ( Husqvarna ) Basically get working . See how much more you have done whilst the Stihl bloke is pissing about with his bar and chain ....
