Lathe woes!
bobh
This is a real long shot but I've just broken the tool rest holder on my coronet major lathe and wondered if anybody might have one tucked away in a back corner that they might want to sell.
Failing that would a good welder be able to sort it, its cast so worried about other fractures which can't be seen yet.
Pictures attached.
Thanks
Bob
Edited by bobh
Pictures attached.
Thanks
Bob
That's a bugger Bob! Hope you get sorted out soon.
I have an extra tool rest holder from my mates lathe possibly. It was a Record CL1 so it should fit ok. Its a while since I have seen it so I will have a hunt for it in the workshop tomorrow. Failing that I would put a wanted ad on one of the woodworking forums or contact record. It would be far cheaper than welding it. Will let you know tomorrow night.
Mike
Mike
Thanks Mike
Just had a look at a few images of the CL1 and it looks like it might just fit, will look out for your post tomorrow.
Pictures attached.
Thanks
Bob
HaHa
For a minute I thought you were going to say you had one!
Got the lathe from George behind the MESS, going to blame him for weakening it. :D
Half an hour in a welders shop will fix that. Your local Ag supplies will have the 'black' rods. Failing that ebay;Cast Iron Repair Rods 3.2mm x 5 Rods arc welding | eBay
Looking at the break you'd be wise to add a wider base plate to spread the downwards forces generated.
codlasher
Not sure my welding is quite up to that. You're probably right about it needing more support as I inherited 2 spares with the lathe, both of them broken!
If needs must I can probably send it off to get it repaired, not sure we have a decent welder on the island.
