Smokey cold start on ranger
Danny boy 88
Just a word of warning, injectors can cause massive engine failure. If it is dribbling rather that spraying a nice jet pattern it can cause the piston to get too hot and it can melt the crown causing it to pick up the cylinder bore! Big money! Other problems if an injector dribbles while the engine is off it can give you a lot of smoke on start up as there is high quantities of diesel in the combustion chamber when you start it! If the injector is dribbling when it's off it may be doing the same when it's running, then the unburnt diesel can find its way into the sump and slowly fill the oil level up, eventually it will get that high it will start running on the diesel/oil mix and rev it's bollocks off until it goes bang!
I would get it checked out sooner rather than later it may save you loads!
Sent via postman pat.
