  • Replies 20
One thing to check out, perhaps gardenkit can help out again, is where it can be used under load for engine braking, I seem to remember on case tractor 4240 the manual said some thing along those lines, as it would cause premature wear.
International harvester tractors have it too, My 885xl has anyway. you dont need to clutch while changing but you should take the load off by dropping the revs off for a moment. Takes the jump out of the change. I do remember reading somewhere that you shouldn't drive for long periods in the low range of the torque amplifier. Not sure how accurate that is though
You don't need the clutch but as has been said, there is no engine braking when in tortoise.
ie. going down a hill it is not much different than free wheeling but in a very not safe way.
True of the old Massey Multi Power, but not of the Zetor.
The Zetor 9540 employs a 3 stage, clutchless torque multiplier with full engine braking. Coupled with the 3f/1rev gearbox and high/low range, the multiplier allows 18f/6rev gears.
Yep tried this out today- theres engine braking OK. What do you mean by 3 stage though, as far as I can tell its either hare or tortoise- no middle ground?
Seeing as you know your zetors- the torque multiplier seems to whine sometimes but not always. Any ideas what this is? Cheers
I have been out of the ag game for a dozen years, but remember the 9540 as having a 3 stage multiplier, but maybe my memory is playing tricks. Do you have a handbook?
i would not worry too much about a whine in a Zetor at speed.
Well, mine doesn't seem to, only 2 stage- unless 9540 models vary. Don't have a handbook or manual but I must get one- they always seem to be translated from polish (?) so I never find the manuals particularly easy to follow.
Anyhow, very pleased with my 9540, seems a strong tractor and a MASSIVE upgrade from my old zetor 7045 which was a disaster on the roads even if it was good in the fields.
