I hope matty is reading this and shipping a delicatessen your way then! He hasn't sent the short block?
I now have the block, handle and an array of parts that may...or may not make a saw - thats life with Matty:sneaky2: It is OK, he is a decent guy and I am only taking the piss.....a little.
I will be interested to see if the saw does what it should once done:thumbup:
Have you ported any 550xps' and will the auto tune adjust enough for it? What sort of money are we talking if so :thumbup1:
I haven't personally done a 550 to date, this 560 I have done has had a life and the top end was hanging on a wire until I worked a little magic. It has had A LOT done to it and if the auto tune handles it then I think others will follow suite.
The machining gets done at the weekend and the rebuild a week later - just too busy to get it done earlier.
Cost - PM me for a few costs if you are interested.
Will see what the outcome of the 560 is and go from there:thumbup1: A ported and tuned 560, that will be a total nutter :thumbup:
They are! Mine out cuts anything I've ran against it!
Need a comparison using the same bar, standard machine if possible!
Forgot to tell you Matty - your piston ring and circlips arrived for the attention of Miss Fxxxxx
I know you wear your hair long but is there something you are not telling me......did that Monty Python Lumberjack song have a lasting effect:001_tt2::lol:
Just kidding:lol:
Just kidding:lol:
Unfortunately I can't compare the same set-up as stock, as I run 9t on 18", whereas the work's saws are 7t 15". Although I'm confident that even with the bigger bar, it'll piss all over them!
