My advice, send it to someone who has the tools, it's a pita! There are c-clips, seals, if it's an older model, the bearings are different too! The whole machine has to be taken to tiny pieces to get at the inner bits!
Oh I don't fancy going through all that. As it would only be used on a mill, do you think that some type of external oiling system would be ok, like low pressure fed into the nose maybe.
Back soon dinners boiling over cheers
Hard to tell, the auxiliary oilers used for milling are usually used in conjunction with the saw's oiler
Mitch back in the States has answered the "What to do when your internet is down" question:
Well, I have tried out my ported 066 "Red eye" and .........what a dissapointment, very boggy in the cut and about as much go as an unported 60cc saw.
I am thinking the ignition advance isn't right as this is the area where I had to set the flywheel manually and not with the conventional key.
The next stage is to fire the saw up and use a timing light on it to see exactly what the ignition timing is - 27.5 - 32.5 deg at 8,000 is what it should be.
Watch this space!
Sounds like the timing is very retarded. But what do I know.
In other news, Randy's finger ported 044 has arrived at my door step. I'll grab some pics tomorrow in day light.
Yup, quite agree, the coil alligns with the flywheel at around 15 -20 deg, same as a 026 but it may be firing at 15 deg instead of 30 deg so retarded by 15 deg.
There is no decomp on it and it isn't ripping the starter handle out of my hands like I would expect running 170psi on a pop up unbedded piston!
Just needs a bit more tlc!
Good luck with the new baby!
