I am about to sell my first logs by volume for firewood and fencing materials. I am happy with how to measure the stack when it is roadside to know what the volume is but do I then need to take air spaces into consideration? If so, how is this done?
Any help would be appreciated.
Being new to the industry, I wondered what sort of figure per m3 or tonne that hardwood is going for roadside for firewood, particularly in the south west - Dorset, Devon, Cornwall, Somerset, Hampshire etc). Anyone willing to give an idea of current prices?
You do need to work out air space in the stack. You need to measure a section and count then number of billets and the area taken up by those billets.
Best thing is to get yourself a copy of the blue book. That has how to measure the stacking coefficent.
Treesource Silviculture, Woodland Creation & Management
Cost per tonne varies. £30-60 quid a tonne. Really depends on this little equation. standing price(m3)+Felling cost (m3)+extraction cost (m3)+profit = roadside price.
  • 6 months later...
Would those knowledgeable in this area think that 30% is a fair amount to allow for air space in a stack of norway spruce such as this?
A stack of perfect cylinders has air spaces of 21.45% so to get logs to stack with 30% they need to be essentially green sawlog grade rather than pulp, also the longer they are the worse so my guess would be that stack is probably more than 30% air.
The more serious inaccuracy is likely to be in measuring as it is a long low stack so edge effects are make measuring difficult and bear in mind there is more air space when loaded between bolsters on a lorry.
More like 35% do you think.
Nowhere near enough:- 45% of that stack is broken stowage (airspace) - big flared butts, bent lengths and some of it with projecting snags.
Even trying to estimated the average height of that stack will be a challenge, since it varies quite a bit.
Cheers
mac
Know it seems to be the old fashioned way of doing it, but it seems a lot less hard work just sending each load out over a weighbridge/using wagons with on board weighers.
Those who worry about mc and/or different species affecting weight - simples, vary the price/T to suit :001_smile:
To me, volume is too easy to manipulate to suit either party.
