Keep the winch very well oiled. I think it was in Griphoist's own literature I read 'you cannot over lubricate the winch'. If I'm working over dirty ground I just pour chain oil into mine.
Put a bit of tape round the caps that hold the spare shear pins.
Personally I have a spare shear pin taked to the bottom of the handle so I always can see I have a spare one without having to check.
I also tape round the shear pin that's in use just in case it drops out when moving or transporting.
As you can guess I have been caught out a few times.
I never take the rope out of the winch, if the end is frayed its a pain to push through the winch. I just wrap rope up and tie up with a cable tie. Also, I don't bother too much with a long rope, use a polypropylene rope attached to wire rope.
