  • Replies 34
As above has anybody converted a dropside pickup to a tipper body?
Whats involved and what sort of cost could it be done for??
I have done it and what it will cost will depend on what skills and resources you have available and whether you want new bits or used.
drop side bodys are not strong enough to be converted to tippers so you need to get the hole body from a tipper. if you buy the hole lot from a breakers the body,pump,sub fram are very easy to swap over done my last one in an afternoon and cost me £1200 for all the bits
Beg to differ. Been there done that.
ive also converted a dropside to tipper on a landy( for josharb) the tipping gear strengthened the original body he got a transit tipping gear from a scrapper then shortened it to suit the landy and it prob cost him no more than £150
converted 3 first one I tried retaining the body but was more hastle than it was worth.
No I meant haw many flats have you made into tippers, answer none, went with the spend more money option.
From the last few posts I don't think the OP has much to spend so putting the effort into the job is probably going to be the option of choice. Your £1200 quid option is most of his vehicle buget
You can pick up a pump/tank unit for a couple of hundred and a hundred quids worth of steel will put a spline in a flat.
Hmmmm it seems there is a difference of opinion here!! Can you retain the body or not that it the question and I guess the answer will be determined by the vehicle and its original back end!
Interesting thoughts though so keep them coming.
As some of you may be aware from the last thread I started I am looking for a new crewcab tipper for £2000 ish or less. well I have found a truck that it well inside the budget but is a dropside so do I buy and convert or just hold out for a tipper to come along?
