  • Replies 24
I use these on my pick up, got four in the grill and only a small sucker attachment light on the back window - these lights are superb. A good family friend who is a mobile mechanic electrican, also a retain fire fighter said their the same ones as the fire engines in Dorset use! Because he fitted them on the fire engines too! Here's what they look like...
Where did you get them funky lights from??
Brittax led repeaters front and back and a mini light bar On top in total drawing less than 10amp so low battery drawn.
Sparex mini work lamps up top at the back 80lume I think and for the size perfect for reversing at night or call out work without frying Your eye's
I am afraid that as with everything you get what you pay for. I run a combination of stuff on my LR.
I have these worklamps for just general hitching trailers unloading kit in dark.
WIPAC Square Worklamp Work light Defender/Recovery NEW | eBay
However when its a case of extended work in the dark I have one of these that I bolt on and plug in a couple of minutes
1 Hella Xenon HID Work Lamp AS200 12V Long Range | eBay
Yep its hellish expensive but I paid a lot less for mine but it is like working in daylight however I would not wanted to leave it bolted to the truck with out shear nuts or something.
Beacons well that's another kettle of fish again I favour LED but quality ones the cheaper suffer from water ingress and will allways let you down when you most need them
I have 10 of these on the back of the 130 yes 10! however they are split between low and high and switched so if trailer is on the the lower 6 don't have to be used.
Details for SecuriLED Amber LED Surface Mount (497032)
I also have 8 of these on the front of the 130 again 4 up high 4 down low and switched accordingly
Details for 12v Amber Multiflash LED (3700)
I am not suggesting anyone needs the quantities I have, I have them because I could and the vehicle gets used for many many different jobs. I have also never paid the full list price for any of them ebay is your friend if you are patient.
