what are you guys using in the ultrasonic cleaner i have been using the carb cleaner from mistral but i do not think it is as good as it use to be what are you using?
I sell the Oregon ultrasonic cleaner fluid my dealers tell me it's very good pm me your contact details
Les
I use water with a few drops of detergent.
Perhaps I should be using special fluid, I thought it was the bubbles exploding on the surface of the item that did the cleaning.
It does the job, a heated tank helps.
H-A
H-A
what make is your cleaner? looks like a good unit how many ltrs?
bill
Thanks guys for your help will try some of the suggestions spud the chemical you use i think is the same as the mistral chemical i use i have been looking at a chemical on ebay just wandered if any of you guys have tried it CARBURETTOR MACHINE PARTS ULTRASONIC CLEANING FLUID ENGINE PARTS FORMULA 5LT | eBay
by the way the cleaner i have is 500w ultrasonic 600w heater 15ltr tank
bill
Edited by BILLSMOWERS
