Timber Lorry Load Dimentions and Payloads
hawthornheavyhorses
  • Replies 22
Matt,
According to Forest Mensuration in general conifer stacks require a con\/ersion factor of 0.7 to allow for air and hard wood between 0.55 and 0.65 depending on the form of the timber.
To con\/ert \/oume to weight, if felled recently and for timber with a mean mid diameter of 20cm the following is recommended:
Oak 0.94 m3 to 1tonne
Ash 1.28 m3 to 1 tonne
Sycamore 1.2 m3 to 1 tonne
firewood at 3.75m for two bays on an 8 wheeler or 3 bays on an artic.
Ditto or we do 3 x 2.2m for an 8 wheeler and 4 x 2.2m for artic. My forwarder is annoying in that I can sling on 2m roundwood fast x 2 bays whereas 2.2 I have to make more effort to make the back bay sticks neat. 8 wheeler doesn't mind as just goes higher on the pins upto 18t or 26m3. Artic gets 35m3 on 2.3s x 4 rammed. Edit, this is for softwood roundwood.
Matt,
According to Forest Mensuration in general conifer stacks require a con/ersion factor of 0.7 to allow for air and hard wood between 0.55 and 0.65 depending on the form of the timber.
To con/ert /oume to weight, if felled recently and for timber with a mean mid diameter of 20cm the following is recommended:
Great. Ok, so assuming 100m3, and a conversion of 0.65 (it is all pretty straight), I have 65 solid cube. 20cm mid diameter is about right and was felled last week so that gives me:
39m3 Oak = 41t
13m3 Ash = 10t
13m3 Syc = 11t
Total= 62t
So enough for at least 2 arctics with a little contingency which is basically what I was trying to work out.
Thanks all!
Hello Matt. We had 2 loads picked up last week, 25.5 t (33 m3) on each. I always go by volume as you don't get penalised if it takes a while for the wood to be picked up, and you and the buyer can stand next to it with a tape measure.
I add 40% for air in the stack, is your's hand stacked ?
Yes hand stacked to 1m, although some of them have taken 4 of us to roll/lift on!
Is the 33m3 before or after the 40%?
Hi Mat
If I were you I would sell by the ton get a printed ticket from the driver or public weighbridge ticket you all know where you are then.
As for stack measure for hardwoods it was always length x width x height x 55% =volume of wood this is quite easy if the driver loads level to top of pins just measure and get your calculator out.
Hope this helps. pity there is so much oak or I would be interested.Chris.
