  • Replies 20
Take the oil pump out and give it right old clean out...
Squirting WD40 in there will hopefully clean and blast any crud out. Had it with a problem on one of my saws and it sorted it a treat.
Yes Rich.....you did didn't you - think I will run a phone service help line as well!
The worm drives rarely wear and the pickup pipe filter or plugged pump are the usual suspects:thumbup:
If these parts are fine then the pumps do wear to the point they stop working:thumbdown:
Take the clutch off - spin it clockwise to do this, remove the clutch drum and bearing, three screws and remove the dual side cover, remove the worm drive, remove the two retaining bolts on the pump and pull it off the oil channel connector block and remove the pipe.
Make sure the same oil pump retaining screws are used to fit the pump back on as if you use longer ones, you will punch a hole in to the inner crank case:thumbdown::thumbdown:
forgot to mention, I was only the hands operating under the telephonic instruction of a god like being.
:blushing::blushing:
Edited by Rich Rule
