Newbie considering going into the log trade!
  • Replies 43
If you can get hold of the timber than what's the harm in giving it a go.
What I would say though is you will more than likely struggle to get hold of any, and if you can, there's half a chance it will be stuff nobody else wants otherwise it wouldn't be out on the open market - pretty much every stick of firewood has a buyer sorted out before the tree hits the floor round here.
i used to do firewood in york before i moved, aim for bagged logs they tend to sell well, for timber i used to offer a free place to dump to the garden maintenance companies, also off the council but tell them what you want otherwise they will dump rubbish
Well thanks for all your advice. From what I have read I think the log job is a no go, to many local firms selling at £60/70/m3. Im not one for working for free!
Best of luck to the rest of you, hopefully this cold weather will help boost your sales.
Regards
Tom
I would advise you to see if truckloads of hardwood are available and how much, as there seems to be very little available.
What, even from yourself Mark:001_smile:
If you have a spare shed, a spare tractor, some spare time and can use the wood in your own home fires you'd have little to lose.
Dependent on what area you are in you may be eligible for a diversification grant of up to 50% of a processor cost. So it could be a quids in at the start venture.
I'd consider buying in three loads of firewood that'd mean an outlay of around £12,000 including the processor cost. From this you could process around 130m3 of wood that'd recoup your outlay and cover fuel. It'd then be a case of seeing how long it'd take to move it at £90/m3 and then you could decide if it is a worthwhile venture.
Edited by baz
Is that with your farmers grant or farmers overdraft pal :001_rolleyes:
